Despre preamplificatoare
Discutii despre sursele de semnal audio, DAC, CD-DVD, SACD, etc
Să începem cu nivelul optim al semnalului procesat :
Nivel semnal .jpg (87.91 KiB) Vizualizat de 3954 ori
addybiru (Mie Iul 20, 2022 8:56 pm) • carageae (Joi Iul 21, 2022 11:19 pm)
Va prezint doua scheme foarte interesante , garantate 100% ca fiind incadrate in categoria Hi-End:
addybiru (Vin Iul 22, 2022 8:29 am)
Description
Elektor Pre-Amp Hi-End 2012
Specifications
Test conditions: supply voltage ±17.6 V; all measurements symmetrical; tone control defeat disabled.
Test equipment: Audio Precision Two Cascade Plus 2722 Dual Domain (@Elektor Labs)
THD+N (200 mV in, 1 V out) 0.0015% (1 kHz, B = 22 Hz – 22 kHz) 0.0028% (20 kHz, B = 22 Hz – 80 kHz)
THD+N (2 V in, 1 V out) 0.0003% (1 kHz, B = 22 Hz – 22 kHz) 0.0009% (20 kHz, B = 22 Hz – 80 kHz)
S/N (200 mV in) 96 dB (B = 22 Hz – 22 kHz) 98.7 dBA
Bandwidth 0.2 Hz – 300 kHz
Max. output voltage (200 mV in) 1.3 V
Balance +6.3 dB to –6.3 dB
Tone control ±8 dB (100 Hz) ±8.5 dB (10 kHz)
Crosstalk R to L –98 dB (1 kHz) –74 dB (20 kHz)
L to R –102 dB (1 kHz) –80 dB (20 kHz)
Câteva detalii :
addybiru (Sâm Iul 30, 2022 4:37 pm)
Schema preamplificatorului :
Elektor-2012-04.pdf
23.33 MiB - Descărcat de 188 ori
Preamplifier 1 Elektor 2012.04.pdf
570.62 KiB - Descărcat de 189 ori
Continuare
Elektornonlinear.ir2012-05.pdf
11.66 MiB - Descărcat de 176 ori
Continuare
Elektornonlinear.ir2012-06.pdf
12.08 MiB - Descărcat de 230 ori
Teorie 1
The Sound of Silence.pdf
17.42 MiB - Descărcat de 65 ori
Teorie 2
Balanced.Phono-Amps[Extension.to.the.The.Sound.of.Silence].pdf
14.82 MiB - Descărcat de 65 ori
