Despre preamplificatoare
Să începem cu nivelul optim al semnalului procesat :
- Nivel semnal .jpg (87.91 KiB) Vizualizat de 2550 ori
Va prezint doua scheme foarte interesante , garantate 100% ca fiind incadrate in categoria Hi-End:
- PreAmplifier.jpg (774.57 KiB) Vizualizat de 2537 ori
- MMC.jpg (271.38 KiB) Vizualizat de 2537 ori
Description
Elektor Pre-Amp Hi-End 2012
Specifications
Test conditions: supply voltage ±17.6 V; all measurements symmetrical; tone control defeat disabled.
Test equipment: Audio Precision Two Cascade Plus 2722 Dual Domain (@Elektor Labs)
THD+N (200 mV in, 1 V out) 0.0015% (1 kHz, B = 22 Hz – 22 kHz) 0.0028% (20 kHz, B = 22 Hz – 80 kHz)
THD+N (2 V in, 1 V out) 0.0003% (1 kHz, B = 22 Hz – 22 kHz) 0.0009% (20 kHz, B = 22 Hz – 80 kHz)
S/N (200 mV in) 96 dB (B = 22 Hz – 22 kHz) 98.7 dBA
Bandwidth 0.2 Hz – 300 kHz
Max. output voltage (200 mV in) 1.3 V
Balance +6.3 dB to –6.3 dB
Tone control ±8 dB (100 Hz) ±8.5 dB (10 kHz)
Crosstalk R to L –98 dB (1 kHz) –74 dB (20 kHz)
L to R –102 dB (1 kHz) –80 dB (20 kHz)
Specifications
Câteva detalii :
- 2325193032452.png (426.81 KiB) Vizualizat de 2510 ori
- 2325197541620.png (307.72 KiB) Vizualizat de 2510 ori
Schema preamplificatorului :
Continuare
Continuare
Teorie 1
Teorie 2
