Electrice si nu numai, stocuri nevandute, etc.
Ciprake
Pot trimite prin fancurier cu verificare colet pret transport 10,15 lei. Cand sunt promotii la transport, 5 lei sau gratis.
Marfa este retur Amazon, poate prezenta urme de desfacere/expunere pe raft.
Conditie excelenta de functionare. Se vinde ca atare, echivalent produs nou.
1. Dispozitiv tip bara de taiat stirofex, cu alimentator
https://ibb.co/yc2mkwrd
https://ibb.co/jZgwPg3t
25 lei
2. Acumulator Atuder 21V 2Ah 2buc
https://ibb.co/9HDGqb5q
https://ibb.co/0jp2Zq57
https://ibb.co/4R5SW4V2
https://ibb.co/hRTFcTt6
https://ibb.co/ds3mc4BS
https://ibb.co/5XK3Cgc7
https://ibb.co/spp3s3Hy
60 lei buc
3. 2 Suflante cu 3 varfuri diferite, una merge cu baterie Bosh si una cu Einhell. Sunt identice doar partea de jos difera, sunt interschimbabile pe aceasi carcasa (mai am una la fel, pe care o pastrez, care are suportul pt Makita).
Nu am baterii la ele. Pentru Einhell pot livra 2 carcase printate 3D la pret de 20 lei buc: https://ibb.co/Jw9VMzPX
https://ibb.co/s9z03BGz
https://ibb.co/DdpLcW8
https://ibb.co/BVxzRndr
https://ibb.co/GfFbvy41
https://ibb.co/NdXHZC1R
https://ibb.co/xKBzmwvx
50 lei buc
Suflanta pt baterie Bosh posibil cu probleme, a pornit cumva doar alimentata din sursa si a tras cam 9A
20 lei
Mai adaug o suflanta cu aer cald pt baterie Makita,defecta, cip si 2 tranzistoare afectate vizibil
https://ibb.co/yv5pThP
https://ibb.co/jZ8PfKCr
https://ibb.co/4RHtx7hz
https://ibb.co/wFRwKnr1
https://ibb.co/HfL4WXQZ
https://ibb.co/sTNGG2N
https://ibb.co/mrj7vsvJ
https://ibb.co/M5BdQTGv
https://ibb.co/ZRptj7nL
35 lei
4. Treedix soldering iron set, 8W wireless soldering iron soldering set with adjustable temperature from 330 to 450 C, including USB cable, soldering wire, iron stand with sponge, 3 soldering tips for soldering
Mini letcon cu incarcare type C
https://ibb.co/5vr6wwB
https://ibb.co/0sJHD36
90 lei setul, 2 seturi disponibile
5. Husa universala, mare, cu incalzire scaun auto la 12V
Stoc 5 buc, negociabil la mai multe.
Eu am pus pe Zafira B din 2013, si pe scaunele din fata si pe cele din spate.
【Ușor de instalat】 Proiectată cu o bază de cauciuc cu poziție fixă și curele de umăr reglabile pentru atașarea la scaunul auto, un cârlig atașează perna scaunului la baza scaunului.
【Potrivire universală】 Se potrivește perfect scaunelor de birou și scaunelor cu rotile, fiind proiectată cu cauciucuri antiderapante pe partea inferioară și echipată cu benzi elastice pentru a fixa perna pe scaun și a o menține perfect la locul ei.
【Materiale moi】 Perna noastră pentru scaun este confecționată din piele moale, care oferă o senzație confortabilă și liniștitoare.
【Stai la locul ei】 Simplu de instalat - echipată cu benzi elastice pentru a fixa perna pe scaun și a o menține perfect la locul ei și proiectată cu cauciucuri antiderapante pe partea inferioară. Baza de cauciuc antiderapantă crește stabilitatea pielii husei scaunului pentru o conducere sigură.
https://postimg.cc/gallery/JRKsCsP
75 lei buc, negociabil la mai multe
6. Creality Storage Box, cutie pentru stocat/uscat pasiv filamente imprimanta 3D, pentru 10 buc
Mi-a venit fara cele 4 bare metalice de imbinare, dar cu suruburi, nu mai stau sa caut inlocuitori.
In primele 3 poze cum ar trebui sa fie
https://ibb.co/XfPfnfMG
https://ibb.co/4gpCyqDN
https://ibb.co/bgWJcmqr
https://ibb.co/9k3GCZnk
https://ibb.co/hxjgT5vt
https://ibb.co/7dKDh3bs
https://ibb.co/RxGsdHD
https://ibb.co/6Jrdcj4G
https://ibb.co/s9hnnDLH
https://ibb.co/spbhwGBd
100lei
7. Transformator toroidal 120V - 230V si invers 500, 2000, 3000VA
Transformator 120V 230V 200VA
200VA 60 lei
https://postimg.cc/cKYZd6CR
Transformator 120V 230V sau 230V 120V de 500VA 400W la 115 lei stoc 3-4 buc
Transformator 120V 230V sau 230V 120V de 1000VA 800W la 175 lei
Transformator 120V 230V sau 230V 120V de 2000VA 1600W la 215 lei
Transformator 120V 230V sau 230V 120V de 3000VA 2400 W la 265 lei stoc 1buc
https://ibb.co/nM6m8v7z
https://ibb.co/JRjSLVzq
https://ibb.co/S7VxsMT4
https://ibb.co/5WkLFFDC
https://ibb.co/Gvf4ZwYT
https://ibb.co/pjkWSh6b
https://ibb.co/Pv2k5p2q
https://ibb.co/HTmjL4T5
8. Versatester E0502 . Porneste, nu stiu daca mai e calibrat, se vinde ca atare.
https://ibb.co/Jjs50cKv
https://ibb.co/BKZsZsdF
https://ibb.co/ym240PkT
https://ibb.co/k2XVqJ9W
https://ibb.co/pvc3bpXz
250 lei
9. Aparat de sudura in puncte
https://postimg.cc/gallery/K1hwtwk
165 lei
10. Module cu telecomanda 2 tipuri, ultimul din poze nu mai este
https://postimg.cc/gallery/dQSp5br
35 lei buc, 60 lei toate
lot 2 module cu 7 telecomenzi
https://postimg.cc/gallery/8f5rvL2
60 lei par ok. trebuie sa le testez
11. Statii meteo cu ceas, alarma si proiectie pe tavan, unul nou in tipla,unul second hand
second hand:
https://ibb.co/PHr02nf
https://ibb.co/m5psbYmh
https://ibb.co/5X00mtWq
https://ibb.co/YFh6sZz1
https://ibb.co/nMvQCLbm
https://ibb.co/MyBfnnGD
https://ibb.co/8Dk45Dm7
https://ibb.co/WNrk66ms
https://ibb.co/zhHg3n2D
https://ibb.co/Rkb12Gsx
https://ibb.co/jPVqQW0y
55 lei
nou in tipla
https://ibb.co/C3KGsqwp
https://ibb.co/8nmnfJhK
https://ibb.co/MDkjG4T9
https://ibb.co/Y7prFLRK
https://ibb.co/qMJqTQww
https://ibb.co/QjDdXTdR
https://ibb.co/sST85Rn
https://ibb.co/mC8w1jRj
https://ibb.co/spnWvwky
https://ibb.co/3y5qDDS4
https://ibb.co/XfrBmyKX
https://ibb.co/yFTtfpGp
https://ibb.co/DHjXFXLw
https://ibb.co/tPvJQ2VJ
https://ibb.co/xtY7YtQd
https://ibb.co/B2N7JNgG
https://ibb.co/FLXfLTKT
100 lei
12. Miniaparat de sudura 140A IGBT
Aparat de sudură mic și portabil, ideal pentru lucrări de reparații și întreținere la domiciliu. Acesta vine într-un ambalaj sigilat, fiind un produs nou și nefolosit.
A FOST SCOS DIN CUTIE SI DOAR VERIFICAT DACA SE ALIMENTEZA, NU S-A SUDAT CU EL.
FEIFANKE ARC140 Super Mini Aparat de Sudură cu Inversor - 140A IGBT Sudură cu Electrozi DC cu Lift TIG, Indicător LED, Anti-Blocare, 210 x 130 x 90mm
https://postimg.cc/gallery/bzysGZR
225 lei
13. Minifreze cu accesorii - nu stiu cat sunt de puternice, se pot opri cu mana, nu am incercat sa le folosesc
https://postimg.cc/gallery/sjbC7Ln
90 lei buc
14. Minifreze cu accesorii, cu alimentator si accesorii, se foloseste alimentat din priza, 2 noi cred 2 sh, se vand ca atare,
se pot opri cu mana, nu am incercat sa le folosesc, alim 12V 1A type C
https://postimg.cc/gallery/G8qr5jx
40 lei buc, 140 lei toate plus inca una mai micuta wireles care da sa plece, nu am incercat s-o repar
15. Tester OBD MOTOPOWER - stiu ca nu functioneaza chiar pe toate masinile
https://postimg.cc/gallery/8GfpPdY
85 lei
16. Surse Hanmatek 30V 10A second hand 3buc
https://postimg.cc/gallery/gX344Jw
https://postimg.cc/gallery/ygr9mzs
255 lei buc
17. Incarcator trotineta electrica 42V 2A
https://postimg.cc/gallery/xqfXnSm
50 lei
18. Veste incalzite, divere modele. Una fara eticheta, sh.
https://ibb.co/ymG8mrzp
https://ibb.co/5x5Q9bsD
https://ibb.co/RG6hp9zF
https://ibb.co/TNLj6Rr
https://ibb.co/JR7ctS0S
https://ibb.co/wh7Vccw4
https://ibb.co/pBPpqQXb
https://ibb.co/0VWfXmwZ
Vesta Sevdiea XXL cu powerbank 175 lei
Vesta Kemimoto XL cu powebank 150 lei
Vesta XL sh fara powerbank 75 lei
19. Xbox 360 - adaptor alimentare, cutie pentru hard disc, alimentator transformare kinect in scanner3D
https://ibb.co/tPWc7Ym4
https://ibb.co/JWwq54VC
https://ibb.co/LXcd9C9j
https://ibb.co/hxQvD01y
https://ibb.co/MDyGFZvJ
25 lei adaptoarul alimentare, stoc 2 buc, 50 lei cutia HDD, 100 lei alimentatorul kinect
20. Carplay / Mirrorlink Android, navigayie doar prin telefon cu Android ( cred ca del a 5 la 7 ), mp5 player radio, telecomanda, camera spate, telecomanda volan, microfon pentru comenzi vocale.
https://ibb.co/211G1Cg8
https://ibb.co/p6b8t9nw
https://ibb.co/Dj0fq1K
https://ibb.co/Fqxj6cPN
https://ibb.co/3mkdP6m5
https://ibb.co/Q3WYs9vS
https://ibb.co/ym7k3gw4
https://ibb.co/DfdgPZVd
200 lei buc
Am si cutie de metal pentru fixare in bord, la 50 lei
https://ibb.co/HTySqzTr
https://ibb.co/JRfRvBsg
21. 3D Printer Nozzle Cleaning Kit, ac de curatare diuza 10 bucati set
Ac de curățare a duzei pentru imprimantă 3D, pentru curățarea duzelor pentru extruder din oțel inoxidabil, 10 bucăți Ace pentru imprimantă de 0,4 mm
https://ibb.co/PzbQknFy
https://ibb.co/gMmXwzmm
https://ibb.co/PZjNf6Gw
https://ibb.co/GfTT35RP
35 LEI
22.
23. Uscator filament imprimanta 3D, Sunlu S1, S4 4 role Chitu Systems 4 role, Sovol/Comgrow dublu
Sunlu S1 2buc, ceva zgarieturi pe capacul transparent, in rest ca noi modelul negru 175 lei buc
https://ibb.co/Kck6dKYV
Sovol / Comgrow 3D alb, pentru 2 role, 225 lei
https://ibb.co/QvNzYhmc
POZE REALE MAI JOS
https://ibb.co/V0QCQsKC
https://ibb.co/35TWnPnm
https://ibb.co/0VF5zf5z
https://ibb.co/Fq8MBk89
https://ibb.co/60q9THb7
https://ibb.co/HfX8CSB1
https://ibb.co/JwT24QYQ
Uscator filamente imprimanta 3D Sunlu S4 pentru 4 role simultan, poate printa cu rolele direct in uscator.
https://postimg.cc/gallery/MpxWJgL
450lei
Uscător de filamente Chitu Systems FilaPartner E1 - Capacitate 4 bobine cu 2 camere detașabile Cutie profesională de uscare a filamentelor pentru PLA, ABS, TPU și PETG - Compatibil cu AMS Lite
https://postimg.cc/gallery/bSK3Yny
600 lei
24. Osciloscop portabil 10MHz / osciloscop digital 2 canale 110MHz
Lățime de bandă superioară de 10 MHz și frecvență de eșantionare de 48 MSa/s - Echipat cu o lățime de bandă și o funcționalitate de eșantionare de vârf în industrie, HO11 captează forme de undă precise în timp real și asigură că niciun detaliu nu este ratat în timpul diagnosticării sau depanării.
Măsurarea tensiunii în mai multe intervale de până la ±400V - Atenuarea dublă a sondei (X1 și X10) acceptă o gamă largă de intrări de tensiune, de la ±40V la ±400V, făcându-l versatil pentru testarea de înaltă și joasă tensiune.
Portabil, ușor și reîncărcabil prin USB: acest osciloscop este conceput pentru profesioniștii aflați în mișcare. Cântărește doar 166 g și dispune de o baterie cu litiu reîncărcabilă de 1800 mAh cu o interfață convenabilă de încărcare de tip C pentru utilizare prelungită pe teren.
Ecran color TFT strălucit de 2,8 inchi - Afișajul de înaltă rezoluție cu vizualizare completă vă asigură că puteți monitoriza semnalele clar și clar chiar și în medii luminoase, în timp ce navigarea intuitivă prin meniu simplifică operarea atât pentru începători, cât și pentru experți.
Declanșare avansată pe margine cu moduri automate, normale și unice - Precizia achiziției semnalului este îmbunătățită de modurile de declanșare personalizabile care asigură performanțe consistente și fiabile atunci când se analizează semnale fluctuante sau intermitente.
200 lei
https://ibb.co/nN8BXLwB
https://ibb.co/SDQBr348
https://ibb.co/s95vr6nS
https://ibb.co/8nfCJcKJ
25. Trusa scule pentru imprimante 3D
Contine suport gradat pentru taiat, pile, perii de sarma, chei, ace diverse marimi pentru desfundat duze, set de minidalti
https://ibb.co/d0N8GvQ8
https://ibb.co/fdNGmJVs
https://ibb.co/27bC0B8M
https://ibb.co/1Ghk2B0b
https://ibb.co/PsT9dV8Y
60 lei, mai este o trusa din care lipsesc daltile, 35 lei
26 . Set 6 aplice mici RGB cu telecomanda, fara baterii ( 3 x AA )
https://ibb.co/5W7K3rh3
https://ibb.co/0ykYkpwD
https://ibb.co/tPqRMCkk
https://ibb.co/x8Bg41c8
https://ibb.co/dssNb9Fj
60 lei
27. Diverse AMC-uri, preturile sunt in poze pe produs
https://ibb.co/cSRB4hy8
https://ibb.co/4wqyNCVv
https://ibb.co/wh6MQX86
https://ibb.co/SXB5sbgW
28. Detectoare fum
Set detector de fum, detector de fum cu suport magnetic, detector de incendiu cu durată de viață de 10 ani, detector de incendiu fotoelectric cu baterie înlocuibilă, 10 bucăți. Au si baterii de 9V incluse.
https://ibb.co/ZpdXR4jP
https://ibb.co/C5Q0x6cb
https://ibb.co/Y4W86Pg0
https://ibb.co/PZ09HQ7G
https://ibb.co/svjm1BDS
https://ibb.co/DHwGxHNv
https://ibb.co/hJRN45Xx
https://ibb.co/rGcK8BLc
235 lei
Detectoare de fum, diverse, 3 buc
https://ibb.co/JRZvT2BB
https://ibb.co/JF2dfPMj
https://ibb.co/mrm1g09d
https://ibb.co/391L3SF6
https://ibb.co/Df8XX20d
https://ibb.co/67RhC5fx
https://ibb.co/sJvWK24K
https://ibb.co/0RRTqmKx
30 lei buc
Detector de fum + monoxid carbon
https://ibb.co/ynWxCgCn
https://ibb.co/qL29V77T
https://ibb.co/R4DZvGJ3
45lei
29. Surse fixe, curent constant pentru LED-uri
12V 10A 35 LEI/buc 2 BUC
https://ibb.co/qMxKCDRC
12V 20A 100 lei
https://ibb.co/MkJbKsxS
https://ibb.co/JN6B5xx
24V 12,5A pt LED-uri 65 lei
https://ibb.co/G3x9mBjW
https://ibb.co/TBF4gS3v
https://ibb.co/dwzSR3Ng
24V 16,5A pt LED-uri 85 lei
https://ibb.co/mFMQHnGL
https://ibb.co/vCn616gJ
https://ibb.co/Ld2rgkM7
https://ibb.co/N6jnLVrD
https://ibb.co/xqR0j6nn
30. Monitor touchcreen 7", PC, laptop, DVR, Rasberry Pi, etc.
Touchscreen Portable Monitor 7 Inch Small Portable Monitor Mini Monitor HD 1024 x 600P IPS Screen, Small Screen for Laptop Xbox PS3 Ras Pi
https://ibb.co/9mPx20WV
https://ibb.co/S7RwvCLZ
https://ibb.co/3HbwcFy
https://ibb.co/QFZQBTQM
https://ibb.co/sJ3PmTwM
https://ibb.co/PsTYwStN
https://ibb.co/C3ftbXHx
250 lei
225lei cu ceva zgarieturi pe spate sau unul nou cu buton power blocat pe pornit
Monitor 10,1 Inch cu hdmi. vga, bnc, difuzoate, cabluri, telecomanda
https://ibb.co/N6Cb5McD
https://ibb.co/sdsm17Pr
https://ibb.co/Jw0qRYHT
225 lei /buc 2 buc 1 buc rezervat 10 zile
Monitor 10" fara touchscreen identic ca cel de 7, doar mai mare
225lei
10 inch wide cu touch in ultima poza e al doilea de sus, poza e pentru comparatie de dimensiuni, 350 lei buc, stoc 2 buc
https://postimg.cc/gallery/TYR3B0t
Monitor 10" fara touchscreen identic ca cel de 7, doar mai mare, cu probleme display ca in poze
https://ibb.co/JFgsm9SK
https://ibb.co/6RRnDs3J
125 lei buc, stoc 1 buc
Mai sunt pe stoc 2 modele cu probleme la display , unul cred ca ceva probleme de contact prost la benzi, altul benzi rupte
https://ibb.co/60nRZdv4
https://ibb.co/083ws8q
https://ibb.co/99cHpQbt
https://ibb.co/KjcXchmv
https://ibb.co/PGrmpmQy
125lei , respectiv 100 lei
31. Detector umiditate lemn ( si nu numai ) Erickhill
https://ibb.co/cSnqtcY1
https://ibb.co/rf4bRKcw
https://ibb.co/zhLrDGVn
https://ibb.co/cSkRDCcp
https://ibb.co/n8bHNXbc
60 lei
32. Detector umiditate lemn ( si nu numai ) Erickhill
3 buc, unul l-am primit cu urme de electrolit de baterie pe el, si bateriile defecte in el, dar perfect functional
https://ibb.co/zV4gQXrv
https://ibb.co/ccTrHJrq
https://ibb.co/jvwNJ642
https://ibb.co/fVX42GtL
https://ibb.co/PZqhN7hF
https://ibb.co/9m88BYmt
40 lei buc , 2 buc 30 lei cel sh
33. Suflanta+aspirator pentru tastatura PC, masina, etc 2 buc
https://ibb.co/Kz82h4jn
https://ibb.co/kV6BZdGh
https://ibb.co/NdZcfD2z
https://ibb.co/3yL0DQ1G
115 lei buc, 200 lei ambele
34. Huse scaune auto rosii, din piele naturala, noi, 3 buc doar spatar sunt
https://ibb.co/VXCtg0j
https://ibb.co/7JggD3x5
https://ibb.co/vxwybr8x
https://ibb.co/cKpmmwXt
https://ibb.co/n8QLrygq
https://ibb.co/tMpFrWgQ
75 lei buc, 200 lei toate
35. Adaptoare pentru M2 de MAC AIR la SATA si 2 x M2 la Mufa SATA pentru server
https://ibb.co/r2KswHXp
https://ibb.co/1Yrq6cRh
https://ibb.co/Xk3j6x6H
https://ibb.co/XkJxW212
50 lei ambele
36. Halba de bere lemn + metal, hand made
https://ibb.co/Nkksj4r
https://ibb.co/4nQ4DM3P
https://ibb.co/DffxwBtb
https://ibb.co/ns31Cdw3
https://ibb.co/fTFxNhT
https://ibb.co/3yH3kf3f
https://ibb.co/FbDL00Cw
https://ibb.co/JRwDndNw
50 lei
37. Lupa pentru telefonul mobil, pentru a mari ecranul cand se urmaresc filme
https://ibb.co/gZNbbzFF
https://ibb.co/6RGxtzxq
https://ibb.co/GvsvhJ8y
https://ibb.co/zThqtdWt
https://ibb.co/21k1z6Wn
https://ibb.co/BHk2Swqy
https://ibb.co/TD8844Zr
30 lei buc 50 lei ambele
38. Rucsac din material asemanator celui de armata, de pe vremuri
https://ibb.co/Wp07dY4h
https://ibb.co/cXYPmZ3j
https://ibb.co/ccq9fgbD
https://ibb.co/ZR3nfqsX
https://ibb.co/39CW28cP
https://ibb.co/XfZ2CSK3
60 lei
39.
40. Letcon Yihua aparat de pirogravat, a fost testat, ca nou
https://ibb.co/20kwR3HD
https://ibb.co/QjQvKfpC
https://ibb.co/XPQC1n5
https://ibb.co/zHZcgKMh
https://ibb.co/Z6Tq86pf
https://ibb.co/bgZ0PYXf
https://ibb.co/RTsgrHmf
https://ibb.co/4wXGJKqL
https://ibb.co/mCtqnmTj
https://ibb.co/KzGmcbPr
70 lei
41. Sursa Hanmmatek defecta, HM310T, 30V 10A cu memorii, conectare la PC
Initial porneste, apoi incepe sa decupleze releul. Nu am incercat s-o repar, doar dioda antiparalel de pe iesire decuplata si montata la loc.
https://ibb.co/LXCyQq4v
https://ibb.co/ymGDNDMm
https://ibb.co/hxmrYCL8
250 lei
42. Baner luminos programabil, pentru camion, masina, etc cu telecomanda
Am primit-o second hand, dar functioneaza perfect.
YAYZA! Panou de afișare cu matrice LED flexibilă programabilă RGB cu mesaje derulante multifuncționale, panou de afișare 595x120MM cu text pentru petrecere, panou publicitar din magazin, mașină, camion
Se alimteaza cu 5V prin cablu TypeC- USB inclus
Se poate programa din telefon cu alte texte si imagini din galerie sau pot fi create noi texte si imagini direct din telefon.
https://ibb.co/ccw92c47
https://ibb.co/XfycBxxB
https://ibb.co/BK2djSyD
https://ibb.co/cc1j3gsN
https://ibb.co/qFr1Pz3b
https://ibb.co/Lz3Y2nNn
https://ibb.co/7tc2Pjhd
https://ibb.co/9HgPwzRD
190 lei
43. Ochelari cu lupe pentru electronisti sau bijutieri
2 modele diferite pretul este pe bucata, sunt nefolosite
https://ibb.co/wr3LCs1z
https://ibb.co/HfWwT2nX
https://ibb.co/LXx2fvRF
https://ibb.co/dJ5jg8Lh
https://ibb.co/FqWsXwrQ
https://ibb.co/BV95NnSK
https://ibb.co/LDf4f3gs
https://ibb.co/kVfLMdQ4
75 lei buc
44. Trusa de scule cu unelte NEGRU-ROZ pentru domnisoare si domnisori
https://postimg.cc/gallery/HcQZr24
200lei
45. Pantaloni impermeabil cu sosete neopren pentru pescari, sh... XXL
https://postimg.cc/gallery/F9ZTr6b
70 lei
46. Pantaloni impermeabili cu cizme si bretele, noi, marimea 42
https://postimg.cc/gallery/ZqgsxBC
165 lei
47. Costum sport pentru bărbați, 5 piese, cu uscare rapidă, colanți, costume de alergare, tricou de compresie, trening de sală, trening de alergare ( XXL) supraelastic subtire
https://postimg.cc/gallery/tbwdHy4
75 lei
48. set 6 condensatori 500F 2,7V SAMWHA, starea din poza
https://postimg.cc/gallery/0vWDm4f
150lei
49.
50.
51.
52. Stillus pt MAc si Surface pro
Pencil 1st Generation for iPad 2018-2025, 20 Mins with USB-C Fast Charging & Tilt & Magnetic Suction, Stylus Pen for iPad 11-6th Gen, Air 3-5/M2/M3, Mini 5-6, Pro 11"/12.9"/13''M4 (White)
https://postimg.cc/gallery/BsmKQpJ
30 lei stoc 2 buc
Stylus Milikilo pentru Microsoft Surface Pro 12/11/10/9/8/X/7+/6/5/4, Surface Go 4/3/2/1, Surface Laptop 1-5/Studio/Book 3/2/1 cu radieră laterală, respingere palmă, sensibilitate la presiune 1024 niveluri
https://postimg.cc/gallery/gdZDx1L
30 lei
53. Adaptor alimentare Mac de la Type-C
https://postimg.cc/gallery/nMmXymk
20 lei, stoc 2 buc
